I have been away for a month or so and 3 snippets stopped working for unknown reason.
Below are the 3 snippets. Can you fix them and determine what happened. They used to work perfectly well.
I suspect it has something to do with the new Improved {if} Command?
{ formtoggle: name=Anti_Platelet_Treatment;formatter=(value) -> "Anti-platelet medication(s) taken - " if value else "No anti-platelet medication, such as a regular low-dose aspirin, is prescribed" } { if: Anti_Platelet_Treatment } { note } Type { endnote } { formmenu: name=anti_platelet_drug; Low-dose aspirin; Clopidogrel (Plavix or Iscover); Low-dose aspirin + Clopidogrel (Co-Plavix); Dipyridamole (Persantin or Asasantin) } { note } Duration { endnote } { formmenu: default=;- for 1;- for 2;- for 3;- for 4;- for 5;- for 6;- for 7;- for 8;- for 9;- for 10;- for 11;- for 12;- for 15;- for 20;- for 24;- for 30;- for 36 } { formmenu: default=;-day;-days;-week;-weeks;-month;-months;-year;-years }
{ formtoggle: name=Reasons_Anti_Platelet_Taken; formatter=(value) -> "Anti-platelet medication(s) taken because of - " if value else "" } { if: Reasons_Anti_Platelet_Taken } { formmenu: name=reason; default=IHD with coronary artery stents inserted within 12 months;IHD with coronary artery stents inserted over 12 months ago;IHD without coronary artery stents;Cerebrovascular disease;Peripheral vascular disease;There is NO recognised clinical indication for taking this treatment;- Other } { if: reason==="- Other" } { formtext: name=Other reason;default= } { thrombotic_risk="HIGH thrombotic risk - thus must continue anti-platelet agents." if (reason=="IHD with coronary artery stents inserted within 12 months") else "LOW thrombotic risk - thus can stop anti-platelet agents." } { low_risk_label="LOW thrombotic risk - thus can stop anti-platelet agents." } { high_risk_label="HIGH thrombotic risk - thus must continue anti-platelet agents." } { endif } { endif }
{ formtoggle: name=Procedure_Bleeding_Risk; formatter=(value) -> "Procedure Bleeding Risk - " if value else "" } { if: Procedure_Bleeding_Risk } { formmenu: name=proc_bleed_risk; default= Low; High } { endif }
Patient's thrombotic risk profile for stopping anti-platelet treatment should be considered as - { =thrombotic_risk }
Guidelines for stopping anti-platelet treatment - { = treatments[anti_platelet_drug][proc_bleed_risk][thrombotic_risk] }
{ note } { treatments=["Low-dose aspirin" = ["Low" = [ low_risk_label = "stop low-dose aspirin for 2-5-days prior procedure", high_risk_label = "continue low-dose aspirin (omit on day of procedure only)" ],"High" = [ low_risk_label = "should stop low-dose aspirin for at least 5-days prior procedure", high_risk_label = "continue low-dose aspirin except for ESD and large colonic EMR (omit on day of procedure only)" ]],"Clopidogrel (Plavix or Iscover)" = ["Low" = [ low_risk_label = "discontinue Clopidogrel therapy 5-7 days before the procedure & replace with low-dose aspirin (omit on day of procedure only). Restart Clopidogrel 5-7 days after the procedure if specimens taken. Otherwise restart the following day", high_risk_label = "discontinue Clopidogrel therapy 5-7 days before the procedure & replace with low-dose aspirin (omit on day of procedure only). Restart Clopidogrel 5-7 days after the procedure if specimens taken. Otherwise restart the following day" ],"High" = [ low_risk_label = "discontinue Clopidogrel therapy 5-7 days before the procedure. Restart Clopidogrel 5-7 days after the procedure if specimens taken. Otherwise restart the following day", high_risk_label = "discontinue Clopidogrel therapy 5-7 days before the procedure & replace with low-dose aspirin (omit on day of procedure only). Restart Clopidogrel 5-7 days after the procedure if specimens taken. Otherwise restart the following day" ]],"Low-dose aspirin + Clopidogrel (Co-Plavix)" = ["Low" = [ low_risk_label = "discontinue dual anti-platelet therapy 5-7 days prior to the procedure & continue with low-dose aspirin alone (omit on day of procedure only). Restart dual anti-platelet therapy 5-7 days after the procedure if specimens taken. Otherwise restart the following day", high_risk_label = "continue dual anti-platelet therapy unchanged" ],"High" = [ low_risk_label = "discontinue dual anti-platelet therapy 5-7 days prior to the procedure & continue with low-dose aspirin alone (omit on day of procedure only). Restart dual anti-platelet therapy 5-7 days after the procedure if specimens taken. Otherwise restart the following day", high_risk_label = "liaise with cardiologist about the risk/benefit of discontinuation of one of the anti-platelet agents (discontinue Clopidogrel for 5-7 days prior to the procedure & continue with low-dose aspirin alone.) Restart dual anti-platelet therapy 5-7 days after the procedure if specimens taken. Otherwise restart the following day" ]],"Dipyridamole (Persantin or Asasantin)" = ["Low" = [ low_risk_label = "continue treatment unchanged", high_risk_label = "continue treatment unchanged" ],"High" = [ low_risk_label = "discontinue treatment 5-7 days before the procedure & replace with low-dose aspirin (omit on day of procedure only). Restart treatment 5-7 days after the procedure if specimens taken. Otherwise restart the following day", high_risk_label = "discontinue treatment 5-7 days before the procedure & replace with low-dose aspirin (omit on day of procedure only). Restart treatment 5-7 days after the procedure if specimens taken. Otherwise restart the following day" ]]] } { endnote: trim=yes } { endif }
{ formtoggle: name=Anti_Coagulant_Medication;formatter=(value) -> "Anti-coagulant medication taken - " if value else "No anti-coagulant medication is prescribed" } { if: Anti_Coagulant_Medication } { note } Type { endnote } { formmenu: name=anti_coagulant_drug; Warfarin; Apixaban (Eliquis); Rivaroxaban (Xarelto); Dabigatran (Pradaxa) } { note } Duration { endnote } { formmenu: default=;- for 1;- for 2;- for 3;- for 4;- for 5;- for 6;- for 7;- for 8;- for 9;- for 10;- for 11;- for 12;- for 15;- for 20;- for 24;- for 30;- for 36 } { formmenu: default=;-day;-days;-week;-weeks;-month;-months;-year;-years }
{ formtoggle: name=Reasons_Anti_Coagulant_Taken; formatter=(value) -> "Anti-coagulant medication taken because of - " if value else "" } { if: Reasons_Anti_Coagulant_Taken } { formmenu: name=coag_reason; default=AF without valvular disease;AF and mitral stenosis;Prosthetic metal heart valve and AF;Prosthetic metal heart valve in mitral position;Prosthetic metal heart valve in aortic position;Xenograft heart valve;greater than 3 months after VTE;less than 3 months after VTE;Thrombophilia syndromes;- Other } { if: coag_reason==="- Other" } { formtext: name=Other reasons;default= } { thromboembolic_ptrisk="HIGH thromboembolic risk - thus must continue anti-coagulant medication." if (coag_reason=="AF and mitral stenosis") or (coag_reason=="Prosthetic metal heart valve in mitral position") or (coag_reason=="Prosthetic metal heart valve and AF") or (coag_reason=="less than 3 months after VTE") else "LOW thromboembolic risk - thus can stop anti-coagulant medication." } { low_risk_labels="LOW thromboembolic risk - thus can stop anti-coagulant medication." } { high_risk_labels="HIGH thromboembolic risk - thus must continue anti-coagulant medication." } { endif } { endif }
Patient's thromboembolic risk profile for stopping anti-coagulant treatment should be considered as - { =thromboembolic_ptrisk }
Guidelines for stopping anti-coagulant medication - { = coagtreatments[anti_coagulant_drug][proc_bleed_risk][thromboembolic_ptrisk] }
{ note } { coagtreatments=["Warfarin" = ["Low" = [ low_risk_labels = "stop Warfarin 5 days before the procedure + check INR prior to the procedure is < 1.5 + restart Warfarin on the evening following the procedure with usual daily dose + check INR 1 week later to ensure adequate anti-coagulation", high_risk_labels = "stop warfarin 5 days before procedure + start LMWH (Clexane) 2 days after stopping warfarin + give last dose of LMWH ≥24 hours before procedure + restart Warfarin on the evening of procedure with usual daily dose continue LMWH until INR adequate" ],"High" = [ low_risk_labels = "stop Warfarin 5 days before the procedure + check INR prior to the procedure is < 1.5 + restart Warfarin on the evening following the procedure with usual daily dose + check INR 1 week later to ensure adequate anti-coagulation", high_risk_labels = "stop warfarin 5 days before procedure + start LMWH (Clexane) 2 days after stopping warfarin + give last dose of LMWH ≥24 hours before procedure + restart Warfarin on the evening of procedure with usual daily dose continue LMWH until INR adequate" ]],"Apixaban (Eliquis)" = ["Low" = [ low_risk_labels = "the last dose of Apixaban (Eliquis) be taken ≥ 48 hours before the procedure + restart Apixaban (Eliquis) on the evening following procedure with usual daily dose", high_risk_labels = "omit morning dose of Apixaban (Eliquis) on the day prior to the procedure + restart Apixaban (Eliquis) on the evening of procedure with usual daily dose" ],"High" = [ low_risk_labels = "the last dose of Apixaban (Eliquis) be taken ≥ 48 hours before the procedure + restart Apixaban (Eliquis) on the evening following the procedure with usual daily dose", high_risk_labels = "the last dose of Apixaban (Eliquis) be taken ≥ 48 hours before the procedure + start LMWH (Clexane) 24 hours after stopping Apixaban (Eliquis) + give last dose of LMWH ≥24 hours before procedure + restart Apixaban (Eliquis) on the evening of procedure with usual daily dose" ]],"Rivaroxaban (Xarelto)" = ["Low" = [ low_risk_labels = "the last dose of Rivaroxaban (Xarelto) be taken ≥ 48 hours before the procedure + restart Apixaban (Eliquis) on the evening following procedure with usual daily dose", high_risk_labels = "omit morning dose of Rivaroxaban (Xarelto) on the day prior to the procedure + restart Rivaroxaban (Xarelto) on the evening of procedure with usual daily dose" ],"High" = [ low_risk_labels = "the last dose of Rivaroxaban (Xarelto) be taken ≥ 48 hours before the procedure + restart Rivaroxaban (Xarelto) on the evening following the procedure with usual daily dose", high_risk_labels = "the last dose of Rivaroxaban (Xarelto) be taken ≥ 48 hours before the procedure + start LMWH (Clexane) 24 hours after stopping Rivaroxaban (Xarelto) + give last dose of LMWH ≥24 hours before procedure + restart Rivaroxaban (Xarelto) on the evening of procedure with usual daily dose" ]],"Dabigatran (Pradaxa)" = ["Low" = [ low_risk_labels = "the last dose of Dabigatran (Pradaxa) be taken ≥ 48 hours before the procedure + restart Dabigatran (Pradaxa) on the evening following procedure with usual daily dose (if eGFR btw 30-50, last dose of drug ≥ 72 hours before procedure + in any patient with rapidly deteriorating renal function -> consult a haematologist)", high_risk_labels = "omit morning dose of Dabigatran (Pradaxa) on the day prior to the procedure + restart Dabigatran (Pradaxa) on the evening of procedure with usual daily dose (if eGFR btw 30-50, last dose of drug ≥ 72 hours before procedure + in any patient with rapidly deteriorating renal function -> consult a haematologist)" ],"High" = [ low_risk_labels = "the last dose of Dabigatran (Pradaxa) be taken ≥ 48 hours before the procedure + restart Dabigatran (Pradaxa) on the evening following the procedure with usual daily dose (if eGFR btw 30-50, last dose of drug ≥ 72 hours before procedure + in any patient with rapidly deteriorating renal function -> consult a haematologist)", high_risk_labels = "the last dose of Dabigatran (Pradaxa) be taken ≥ 48 hours before the procedure + start LMWH (Clexane) 24 hours after stopping Dabigatran (Pradaxa) + give last dose of LMWH ≥24 hours before procedure + restart Dabigatran (Pradaxa) on the evening of procedure with usual daily dose (if eGFR btw 30-50, last dose of drug ≥ 72 hours before procedure + in any patient with rapidly deteriorating renal function -> consult a haematologist)" ]]] } { endnote: trim=yes } { endif }
{ pronoun="he" if (title=="Mr.") or (title=="Mister.") else "she" }
{ pronoun_cap="He" if (title=="Mr.") or (title=="Mister.") else "She" }
{ pos_pronoun="his" if (title=="Mr.") or (title=="Mister.") else "her" }
{ pos_pronoun_cap="His" if (title=="Mr.") or (title=="Mister.") else "Her" }
