Ability to hide or minimize the right-side navigation panel
Please consider adding a feature for the ability to hide or minimize the right-side navigation panel where the options are for sharing, disabling and deleting folders.
Hi @aberylyman Welcome back to the forum! :slight_smile:
I assume you're referring to this side bar on the right side (as shown in image).
Can you please help us understand the use case of your request? For example: is your use case to create more space for the folder name and description?
Are you referring to shared folders only or is this request also for personal (not shared) folders?
