Adding Characters When Inserting to Datablaze
Hi TB Community,
A few questions from me today.
I am documenting the price of properties in this way - so that there is less room for error when entering a property price:
The only issue is that when I send it to Datablaze - it only shows up like this:
What would be the right way to tell TextBlaze to add in the $ (before) and ,000 (after) when sending this data to Datablaze?
I am open to any suggestions
Thank you!
Andrew
Hi @ajduna7,
I suggest creating a new variable using concat function as {formattedprice=concat("$", price, ",000")} and insert that in the Data Blaze table for price.
Thank you Ashwin! That worked perfectly :slight_smile:
