Would it be possible to add an option to calibrate typing speed via an interactive text box that asks you to type a paragraph, and dynamically measures you WPM rating?
Potentially. However, I feel the defaults are pretty good.
Are you running into issues where people are typing too slow for the default speed and not realizing they can adjust the slider?
I type at the same speed that an average person speaks. With the slider set to accommodate the fastest typing speeds, I still find myself having to backspace and retype my shortcut slower several times per day for TextBlaze to pick up on it.
Hi Deborah, it sounds like you should adjust the slider to the slower end, not the faster end. The more it's on the slower end the more it allows you to pause between characters.
