Auto-Expandable Form Fields
I want the ability to set formtext and formparagraph field to auto-expand horizontally and/or vertically, so that when the user inputs content that exceeds the columns/rows, the form expands automatically a needed row/column at a time.
Example: I have a snippet that has several form paragraph fields in it. In order to keep the form nice and tidy, I have them all set to 60 columns by 4 rows. Often though, the user inputs data that is copy/pasted from Salesfroce and will surpass 4 rows because of how it is formatted. It may be a block of notes and a students address. In order to see those notes, the user needs to manually expand the formparagraph by clicking and dragging the handle at the lower-right of the box, or scroll up. Small gestures to make, but the compound effect is quite significant.
Thank you as always, for considering.
-Brad :fire:
Hi @Brad_Hedinger.
Thanks for always sharing your thoughts with us. We'll look into it and let you know once we have any updates.
Hey Community. It might help if the requester shares their sample scenario directly with the support team so you can see exactly how they’re structuring the form fields. If a solution is found, it would be amazing to publish a simplified sample scenario as a reusable snippet for the community. I imagine others would benefit from the same pattern/setup or spark some other unique workflows. Many thanks!
Hi @Cortney_Kolbee, welcome to the forum. :slight_smile:
Thanks for your suggestion. We're always pleased to receive any sample scenarios for requested features directly. Feel free to reach us at any time with all your thoughts and questions.
Here you go, @Cortney_Kolbee. Try this. Copy/paste my initial post above into the field below. Then you will see how a majority if the content is out of view. You can grab the handle at the bottom right of the field to expand it manually, or scroll down/up. My feature request is to have the form field automatically expand to accommodate the inserted content; This would be an option that could be toggled on/off in the command settings. Hope that helps! -Brad
{formparagraph: name=Comments; cols=60; rows=4}
Is there a lot of copy/pasting? All from the same space?
Could you have it read the data off the salesforce tab and autopopulate the fields instead? I've done this for something we need to pull a lot of content from SF and send it to something else.
You could also do a clipboard read instead, but that really only works if it's a singular c/p and doesn't fix the box size issue, just prepopulates.
All that to say, these are adjacent ideas and the request itself for a snap to content size would be helpful, so I'll upvote anyway :slight_smile:
Thanks @Kevin_Roberts! They source from varying places depending on the interaction the advisor is engaged with at any particular time. I do have a majority of our snippets reading info from the SF screen and either inputting it, passing it to other apps, or using it to conditionally trigger logic scenarios though.
