Blank line after toggle field
When using the toggle field, is there a way to remove the blank line space if nothing is chosen?
Hi @Kim_Cristarella - welcome to the forum.
The way to do that is using the trim setting. Here's a practical example:
First line of text.
{formtoggle: name=optional 1}Optional line of text 1.
{endformtoggle: trim=right}
{formtoggle: name=optional 2}Optional line of text 2.
Last line of text.
Hope this helps :slight_smile:
You can learn more about how to use the trim setting here:
