How do you get bolt text and formatting to work properly? For my snippet, I have certain words bolded and spaces throughout but when I go to use it, everything is bolded and there are no spaces at all between the different lines of text.
Hi, welcome to the community!
Can you tell which website you using the snippet on? Also, if possible, could you share the snippet itself? You can share your snippet by clicking the Share button on the bottom right of the snippet editor.
