BUG or a glitch
New Snippets are not getting triggered. What to do ?
You can try reloading the extension by right-clicking and then going to Text Blaze, then 'Reload Extension.'
Also, please make sure you don't have conflicting shortcuts or a snippet with a shortcut of just '/'.
If those steps don't help, please email us at support@blaze.today.
Another possible step to take may be to purge your browser of excess baggage (memory).
Copy/paste this into your address bar: chrome://settings/clearBrowserData
Select the "Advanced" option. Leave the default checkbox selections. Don't worry - saved passwords and bookmarks will not be deleted.
Once the trash is taken out, I find this fixes all sorts of stuff. You'll have to log back in to things, but minor inconvenience. Good luck!
