Capital sensitive triggers
Hello, I have seen a lot of talk about capital sensitizing snippets but I haven't found anything about if a trigger can be capital sensitive. We have employees using similar triggers like "ECO" and "ECo" that we would like to use for different snippets however it doesn't like that they start out the same. Is there anyway to make the triggers case sensitive?
Hi @echapman,
You can learn about case sensitive snippets here: Text Blaze | {snippet}. Here is an example for it using our {import} command.
{if: {snippet: trigger} = upper({snippet: trigger}); trim=yes}
{import: /snip1}
{elseif: {snippet: trigger} = lower({snippet: trigger}); trim=yes}
{import: /snip2}
{else: trim=yes}
{import: /snip3}
{endif: trim=yes}
