I am having a blast with Gmail command pack, but I noticed something that takes time when using it. Something the name in the contact is all upper case or all lower case, I want to retrieve the name as it is using {gmail-firstname: type=single} but then I want to capitalize what ever I get from the command into the first letter upper case, the rest lower case example; "JOHN" into "John".
Is this possible?
