Admin Session
Date:
Tracking report itself does not need to be uploaded to Sell for admin sessions. Use the report to help you with your notes below in addition to the answers from the admin feedback survey.
Please also remember to also do the following:
Sell
- Check “Admin Session Booked” date is against Sell record.
- Check you are set as the "Customer Contact" on Sell record.
- Check "Admin Trainer" field is updated on Sell record.
- Send “Admin Session Follow Up” macro on the relevant ticket.
- Change video access settings on Google Drive recording of the session.
- Paste recording within follow up ticket prior to marking as “Solved”
Attendance
Number of attendees:
Names:
Duration: (Please refer to the attendance report to support the below/remove as necessary)
- All attended the full day
- User X kept leaving and rejoining, this implies an internet connection issue.
- User X only stayed on for the training for the first hour.
Competence/Engagement (Please use the chat box transcript to support some of your answers).
- How did they do in practical tasks? All fine / User X was using a phone so couldn’t / User X does not grasp IT at all so I moved on.
- Were cameras on? Yes. / No. / Some users.
- Did they ask questions in the chat box or by unmuting?
- Did anyone ignore you when you spoke to them directly? No. / Yes…
Other (Type response below final dotted line - you do not have to answer each question individually, they are prompts about what to comment on).
- Do you have any obvious concerns?
- Have they used Clearcare before at another organisation?
- Did they mention if they are not yet Ofsted registered?
- Did they say anything complimentary about the system/negative about functionality?
- Is there anything else they asked for that you need to send out? Rollout pack, security information etc.
- Anything else noteworthy/needs following up/you deem to be important.
