Copy of snippet "BHS Character Sheet"
Generate an 8K ultra-realistic multi-section character reference sheet with this layout:
LEFT SECTION, 3 vertically stacked full-body panels, same scale and framing:
Front view, arms relaxed, eye-level
Left-facing side profile, neutral stance
Rear view, upright posture
If no shoes are specified, character is barefoot.
TOP RIGHT, 6 headshots in 2x3 grid, tight head-and-shoulders, identical crop, lighting, scale, clean negative space:
Row 1, front neutral, downward tilt, rear head
Row 2, left profile, upward tilt with chin raised, underside of jaw and neck clearly visible with natural tension and light on lower planes, right profile
BOTTOM RIGHT, 8-panel detail grid, macro-consistent from same shoot:
Face close-up with full head visible, eyes crop, skin crop, nose crop
Emotion portraits, each clearly labeled with clean minimal text placed subtly beneath or within the frame:
Laughter, open smile, squinting eyes, relaxed cheeks
Scream, mouth wide, neck tension, intense expression
Flirtation, slight tilt, half smile, soft eye contact
Suspicion, raised brow, narrowed eyes, pressed lips
GLOBAL:
Same character across all panels, identity locked, no repeated angles, neutral white seamless background, consistent soft studio lighting, professional fashion casting sheet aesthetic, anatomically correct.
REALISM:
Skin shows real pores, variation, micro-creases, vellus hair, uneven tone, natural oil sheen, no smoothing.
Eyes with iris variation, lash separation, subtle skin texture, moisture on lower lid.
Mouth with lip lines, tonal variation, soft edges, asymmetry.
Nose with pores, fine hairs, soft highlight.
Hair with strand detail, flyaways, natural density, no artificial shine.
FINAL PASS:
Skin must render with full physical realism at all scales, visible pore depth, micro-shadowing, vellus hair, uneven sebum, subsurface variation. Lighting reveals texture, preserves shadow detail, avoids clipping. Sharpness must feel optical, grain natural. No airbrushing, plastic skin, or symmetry artifacts. Any artificial-looking skin is a failure.
