Copy of Snippet "CopyHPI3"
Generic Medical HPI
{x={random-number: min=1; max=3}}{formtext: name=complaint}
{if: x==1}The {=lower(complaint)} has been going on for {formmenu: a few\ ; several\ ; many\ ; default=; one\ ; two\ ; trim=no; name=duration1}{if: duration1=="one "}{formmenu: hour\ ; default=day\ ; week\ ; month\ ; year\ ; name=duration2}{else}{formmenu: hours\ ; default=days\ ; weeks\ ; months\ ; years\ ; name=duration3}{endif}{formmenu: and is described as mild.\ ; and is described as moderate.\ ; and is described as severe.\ ; default=.\ ; and is described as controlled.\ ; and is described as uncontrolled.\ ; name=Severity}{formmenu: Symptoms are constant.\ ; Symptoms are intermittent.\ ; default=; name=Timing}{formmenu: The symptoms improve with\ ; The symptoms do not improve with\ ; default=; name=Improve}{if: improve=="The symptoms improve with " OR improve=="The symptoms do not improve with "}{formtext: name=improve_sp}{endif}{if: improve==""}{else}. {endif}{formmenu: The symptoms are worsened with\ ; The symptoms are not worsened with\ ; default=; name=worsen}{if: worsen=="The symptoms are worsened with " OR worsen=="The symptoms are not worsened with "}{formtext: name=worsen_sp}{endif}{if: worsen==""}{else}. {endif}{formmenu: The issue is primarily located at the\ ; default=; name=pre_location}{if: pre_location==""}{else}{formtext: name=location}{endif}{if: pre_location==""}{else}. {endif}{formmenu: The patient also describes the following associated symptoms:\ ; default=The patient denies any associated symptoms.; ; name=Assoc_pre}{if: assoc_pre=="The patient also describes the following associated symptoms: "}{formtext: name=Assoc}{endif}{if: assoc_pre==""}{else}. {endif}{endif}{if: x==2}The {=lower(complaint)} has been going on for {formmenu: a few\ ; several\ ; many\ ; default=; one\ ; two\ ; trim=no; name=duration1}{if: duration1=="one "}{formmenu: hour\ ; default=day\ ; week\ ; month\ ; year\ ; name=duration2}{else}{formmenu: hours\ ; default=days\ ; weeks\ ; months\ ; years\ ; name=duration3}{endif}{formmenu: and is described as mild.\ ; and is described as moderate.\ ; and is described as severe.\ ; default=.\ ; and is described as controlled.\ ; and is described as uncontrolled.\ ; name=Severity}{formmenu: The patient states that symptoms are constant.\ ; The patient states that symptoms are intermittent.\ ; default=\ ; name=Timing}{formmenu: The issue is primarily located at the\ ; default=; name=pre_location}{if: pre_location==""}{else}{formtext: name=location}{endif}{if: pre_location==""}{else}. {endif}{formmenu: Symptoms improve with\ ; Symptoms do not improve with\ ; default=; name=Improve}{if: improve=="Symptoms improve with " OR improve=="Symptoms do not improve with "}{formtext: name=improve_sp}{endif}{if: improve==""}{else}. {endif}{formmenu: The symptoms are worsened with\ ; The symptoms are not worsened with\ ; default=; name=worsen}{if: worsen=="The symptoms are worsened with " OR worsen=="The symptoms are not worsened with "}{formtext: name=worsen_sp}{endif}{if: worsen==""}{else}. {endif}{formmenu: The patient also describes the following associated symptoms:\ ; default=The patient denies any associated symptoms.; ; name=Assoc_pre}{if: assoc_pre=="The patient also describes the following associated symptoms: "}{formtext: name=Assoc}{endif}{if: assoc_pre==""}{else}. {endif}{endif}{if: x==3}The {=lower(complaint)} {formmenu: is constant and; default=is intermittent and; ; name=timing}{if: timing==""}has been{else}{endif} present for {formmenu: a few\ ; several\ ; many\ ; default=; one\ ; two\ ; trim=no; name=duration1}{if: duration1=="one "}{formmenu: hours\ ; default=day\ ; weeks\ ; months\ ; years\ ; name=duration2}{else}{formmenu: hours\ ; default=days\ ; weeks\ ; months\ ; years\ ; name=duration3}{endif}{formmenu: \ The symptoms are described as "mild".\ ; \ The symptoms are described as "moderate".\ ; \ The symptoms are described as "severe".\ ; default=.\ ; The symptoms are described as "controlled".\ ; The symptoms are described as "uncontrolled".\ ; name=Severity}{formmenu: The patient states there is improvement with\ ; The symptoms have not improve with\ ; default=; name=Improve}{if: improve=="The patient states there is improvement with " OR improve=="The symptoms have not improve with "}{formtext: name=improve_sp}{endif}{if: improve==""}{else}. {endif}{formmenu: Symptoms have worsened with:\ ; Symptoms have not worsened with:\ ; default=; name=worsen}{if: worsen=="Symptoms have worsened with: " OR worsen=="Symptoms have not worsened with: "}{formtext: name=worsen_sp}{endif}{if: worsen==""}{else}. {endif}{formmenu: The patient also describes the following associated symptoms:\ ; default=The patient denies any associated symptoms.; ; name=Assoc_pre}{if: assoc_pre=="The patient also describes the following associated symptoms: "}{formtext: name=Assoc}{endif}{if: assoc_pre==""}{else}. {endif}{formmenu: The issue is primarily located at the\ ; default=; name=pre_location}{if: pre_location==""}{else}{formtext: name=location}{endif}{if: pre_location==""}{else}. {endif}{endif}
