Here is a textblaze I made for marking if you would like to use it.
Your justification for the research question is {formmenu: below expectations; default=adequate; clear; clear and detailed}. Your action plan is {formmenu: incomplete; default=quite detailed but incomplete; somewhat detailed; quite detailed; completed in depth}. Your research notes are {formmenu: very limited; default=very limited and not in bullet points; somewhat relevant and in bullet points; somewhat relevant but not in bullet points; relevant and in bullet points; relevant but not in bullet points; consistently relevant and in bullet points; consistently relevant but not in bullet points}.
The information in your body paragraphs {formmenu: does not follow PEAL; default=somewhat follows PEAL; mostly follows PEAL; effectively follows PEAL}. The description of how your city is shaped by migration, trade, or colonialism is {formmenu: incomplete; default=limited with minimal; basic with some detail; fairly detailed; thoroughly detailed\ } and contains {formmenu: no evidence from your research; default=minimal evidence from your research; some evidence from your research; good evidence from your research; strong evidence from your research}. In regards to your sources and your works cited you have {formmenu: not cited your sources in MLA format; default=partially cited your sources in MLA format; mostly cited your sources in MLA format; cited your sources flawlessly in MLA format}.
