GRADING:<br>
{formtoggle: name=Modify weight of course examinations; default=no}Modify weight of course examinations<br>
{endformtoggle}{formtoggle: name=Modify weight of course components; default=no}Modify weight of course components<br>
{endformtoggle}{formtoggle: name=Use weekly grade checks; default=no}Use weekly grade checks<br>
{endformtoggle}{formtoggle: name=Pass/Not Pass contract; default=no}Pass/Not Pass contract<br>
{endformtoggle}{formtoggle: name=Other 1; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 2; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 3; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 4; default=no}Other: {formtext}<br>{endformtoggle}<br>
TEXT:<br>
{formtoggle: name=Record; default=no}Recorded<br>
{endformtoggle}{formtoggle: name=Audio; default=no}Audio<br>
{endformtoggle}{formtoggle: name=Digital; default=no}Digital<br>
{endformtoggle}{formtoggle: name=Braille; default=no}Braille<br>
{endformtoggle}{formtoggle: name=Highlighted; default=no}Highlighted<br>
{endformtoggle}{formtoggle: name=Provide home set of textbooks/materials; default=no}Provide home set of textbooks/materials<br>
{endformtoggle}{formtoggle: name=Study guides; default=no}Study guides<br>
{endformtoggle}{formtoggle: name=Large Print; default=no}Large Print<br>
{endformtoggle}{formtoggle: name=Adapted or simplified text/material; default=no}Adapted or simplified text/material<br>
{endformtoggle}{formtoggle: name=Other 5; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 6; default=no}Other: {formtext} <br>
{endformtoggle}{formtoggle: name=Other 7; default=no}Other: {formtext} <br>
{endformtoggle}{formtoggle: name=Other 8; default=no}Other: {formtext}<br>{endformtoggle}<br>
LECTURES:<br>
{formtoggle: name=Recorded; default=no}Recorded<br>
{endformtoggle}{formtoggle: name=Note taking assistance; default=no}Note taking assistance<br>
{endformtoggle}{formtoggle: name=Other 9; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 10; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 11; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 12; default=no}Other: {formtext}<br>{endformtoggle}<br>
TEST/EXAMS:<br>
{formtoggle: name=Oral; default=no}Oral<br>
{endformtoggle}{formtoggle: name=Short answer; default=no}Short answer<br>
{endformtoggle}{formtoggle: name=Extended time for completing; default=no}Extended time for completing {formtext: name=-Not to exceed last day of semester; default=-Not to exceed last day of semester}<br>
{endformtoggle}{formtoggle: name=Recorded\ ; default=no}Recorded<br>
{endformtoggle}{formtoggle: name=Multiple Sessions; default=no}Multiple Sessions<br>
{endformtoggle}{formtoggle: name=Exams of reduced length; default=no}Exams of reduced length- {formtext}<br>
{endformtoggle}{formtoggle: name=Open book exams; default=no}Open book exams<br>
{endformtoggle}{formtoggle: name=Read test to student; default=no}Read test to student {formtext: name=-Text-to-Speech; default=-Text-to-Speech}<br>
{endformtoggle}{formtoggle: name=Modify test format; default=no}Modify test format<br>
{endformtoggle}{formtoggle: name=Record student responses; default=no}Record student responses<br>
{endformtoggle}{formtoggle: name=Alternative setting; default=no}Alternative setting<br>
{endformtoggle}{formtoggle: name=Read test to student using DVD or recorded format; default=no}Read test to student using DVD or recorded format<br>
{endformtoggle}{formtoggle: name=Other 13; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 14; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 15; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 16; default=no}Other: {formtext}<br>{endformtoggle}<br>
ENVIRONMENT:<br>
{formtoggle: name=Alter physical room arrangement\ ; default=no}Alter physical room arrangement <br>
{endformtoggle}{formtoggle: name=Adjustments for speech intelligibility/fluency; default=no}Adjustments for speech intelligibility/fluency<br>
{endformtoggle}{formtoggle: name=Study carrel for independent work; default=no}Study carrel for independent work<br>
{endformtoggle}{formtoggle: name=Other 17; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 18; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 19; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 20; default=no}Other: {formtext}<br>{endformtoggle}<br>
ASSIGNMENTS:<br>
{formtoggle: name=Read directions to student; default=no}Read directions to student {formtext: name=-Text-to-Speech; default=-Text-to-Speech}<br>
{endformtoggle}{formtoggle: name=Provide recorded directions to student; default=no}Provide recorded directions to student<br>
{endformtoggle}{formtoggle: name=Allow copying from instructional resource; default=no}Allow copying from instructional resource<br>
{endformtoggle}{formtoggle: name=Lower difficulty level-shorten assignments; default=no}Lower difficulty level-shorten assignments<br>{formmenu: Adapted Portfolio Assignments\ ; Reduced number of assessment questions; multiple=yes}<br>
{endformtoggle}{formtoggle: name=Directions given in a variety of ways; default=no}Directions given in a variety of ways<br>
{endformtoggle}{formtoggle: name=Reduce paper/pencil tasks; default=no}Reduce paper/pencil tasks<br>
{endformtoggle}{formtoggle: name=Give oral cues/prompts; default=no}Give oral cues/prompts<br>
{endformtoggle}{formtoggle: name=Allow student to record or keyboard assignments; default=no}Allow student to record or keyboard assignments<br>
{endformtoggle}{formtoggle: name=Adapt worksheets and packets; default=no}Adapt worksheets and packets<br>
{endformtoggle}{formtoggle: name=Avoid penalizing for penmanship; default=no}Avoid penalizing for penmanship<br>
{endformtoggle}{formtoggle: name=Avoid penalizing for spelling errors; default=no}Avoid penalizing for spelling errors<br>
{endformtoggle}{formtoggle: name=Extended time for completion; default=no}Extended time for completion {formtext: name=Not to exceed last day of semester; default=Not to exceed last day of semester}<br>
{endformtoggle}{formtoggle: name=Provide study aids; default=no}Provide study aids<br>
{endformtoggle}{formtoggle: name=Maintain assignment notebook; default=no}Maintain assignment notebook<br>
{endformtoggle}{formtoggle: name=Provide structured time for organization of materials ; default=no}Provide structured time for organization of materials<br>
{endformtoggle}{formtoggle: name=Assistance in recording assignments; default=no}Assistance in recording assignments<br>
{endformtoggle}{formtoggle: name=Other 21; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 22; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 23; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 24; default=no}Other: {formtext}<br>{endformtoggle}<br>
REINFORCEMENT:<br>
{formtoggle: name=Use positive/concrete reinforcers; default=no}Use positive/concrete reinforcers<br>
{endformtoggle}{formtoggle: name=Repeated review and drill; default=no}Repeated review and drill<br>
{endformtoggle}{formtoggle: name=Frequent reminders of rules; default=no}Frequent reminders of rules<br>
{endformtoggle}{formtoggle: name=Check often for understanding/review; default=no}Check often for understanding/review<br>
{endformtoggle}{formtoggle: name=Frequent eye contact/proximity control; default=no}Frequent eye contact/proximity control<br>
{endformtoggle}{formtoggle: name=Other 25; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 26; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 27; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 28; default=no}Other: {formtext}<br>{endformtoggle}<br>
PACING:<br>
{formtoggle: name=Extended time for oral responses; default=no}Extended time for oral responses<br>
{endformtoggle}{formtoggle: name=Extended time for written responses; default=no}Extended time for written responses<br>
{endformtoggle}{formtoggle: name=Allow frequent breaks/vary activities; default=no}Allow frequent breaks/vary activities<br>
{endformtoggle}{formtoggle: name=Other 29; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 30; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 31; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 32; default=no}Other: {formtext}<br>{endformtoggle}<br>
OTHER:<br>
{formtoggle: name=Other 33; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 34; default=no}Other: {formtext}<br>
{endformtoggle}{formtoggle: name=Other 35; default=no}Other: {formtext}<br>{endformtoggle}<br>
