Please can somebody point me in the right direction?
How can create a snippet that creates a clickable webpage link which has a clipboard text inserted? For example:
https://myURL.com/(clipboard item)/theRestOfTheAddress
I'm sure this must be possible, and I think I may have missed something.
Hi @Anon_Brown Welcome to the forum!
Try this:
I have used the {link} command. You can press the "Copy to Text Blaze" button to copy this to your dashboard.
Awesome, thank you. I didn't realise that I could insert text-based commands inside of Widgets (is that the correct term?)
Thank you again
We use the term 'chip' the most. 'Capsule'/'bubble' also work fine. I think Widget sounds cooler than others, so feel free to call it that
As I understand it, pretty much anywhere you see a textbox in the snippet editor, you can put Text Blaze commands inside it.
