Can we please CNTRL + Enter be the dedicated shortcut to insert a snippet please
There are times I'm in a form field and I want to insert the snippet, but have to either TAB all the way to 'Insert Snippet' or use my mouse.
Hi Nigel,
Thanks for your post. Are you using the extension or the desktop app? I am able to insert snippets by hitting only Enter while I am in text fields or dropdown menus in the extension, and while I am in text fields in the desktop app. However, when in a paragraph field, Enter instead maps to adding a new line.
Can you clarify which field type you are in when you'd like to insert with CNTRL + Enter, so we can look into this further? Thanks for your feedback!
Best regards,
Alexander
Hi Alexander,
My mistake. Like you mentioned, the paragraph field and the biggest one for me being 'dbselect' is where I can't insert the snippet hitting Enter.
Hi Nigel,
Thanks for the clarification. I'll look into this further and get back to you soon!
Best regards,
Alexander
