Hi Text Blaze,
In the snippet example below, when the second option is selected for a recall procedure (Gastroscopy in this example) an automatic date is generated a n
months in the future. The default number of months (being the most commonly utilized is 12. However, often it could be 6 or 18 or 24 or 36 or 60 or 120 etc etc.
I would like that the number 12 be highlighted when the second option (Recall Gastroscopy) is selected so that I can simply type a number if required rather than having to use my mouse to place the cursor in the text box and highlight the default 12. I tried {cursor} but it doesn't work inside a formula or formmenu. Below is the snippet.
Thanks in advance.
{if: not Recall_Gastroscopy}{formtoggle: name=No_Recall_Gastroscopy; default=yes}Patient does not require a follow-up or recall Gastroscopy.{endformtoggle}{endif}{if: No_Recall_Gastroscopy}
{else}{note: insert=no; preview=yes}
{endnote}{endif}{formtoggle: name=Recall_Gastroscopy}Patient will require a follow-up or recall Gastroscopy in: {formtext: name=Gast_recall_months; default=12; cols=3} months -> {time: DD-MMM-YYYY; shift={=Gast_recall_months}M}{endformtoggle}{if: No_Recall_Gastroscopy or Recall_Gastroscopy}{endif}{if: Recall_Gastroscopy}
{endnote}{endif}
