I write my snippets with two spaces after each period. Depending on the context, the double spaces are trimmed down to single spaces when the snipped executes. The only ways I've found to correct this are either going back after the snippet executes and add the space back in manually, or insert both a space as normal plus a {key: space} between sentences. Is there some other (simpler) way to ensure my sentences maintain my preferred archaic (aka classic) spacing?
Hey @Ryan_Bortz ,
We're happy to look into this. Can you give a few examples for apps in which this happens?
