Goal: to be able to track imported "child" snippet use from a central "parent" snippet in Data Blaze.
tried setting up a variable in the original snippet, but the import command is overriding. Is there a way of working around and extracting the imported snippet shortcut info?
Hey @Bear_Marshall,
The variables that you set in the "child" snippet are accessible in the "parent" snippet. Is it possible that you are using the same variable name in the parent snippet that might be overriding the child snippet variables?
Also, if you could share an example of both the parent and child snippet here, I can look into it and help you debug.
Best
Samay
