Feature Request: Bulk Import for {randomize} (CSV/TXT datasets + one-click management)
Hi Text Blaze team,
Problem
I use {randomize} with 100+ options. Today, I have to add each item one by one—and when I no longer need them, I have to delete them individually and rebuild new sets. {randomize} is perfect for drawing from a large “database” of keywords/phrases, but adding/removing at scale is painful.
What I’m asking for
A way to bulk import and manage {randomize} options from a dataset, e.g.:
Import from CSV or TXT (one value per line or columns), or paste a list into a multiline field.
Dataset Manager to create, name, edit, reuse, and delete datasets (not just per-snippet lists).
Optional weights and tags/categories for finer control.
Export/Import datasets (CSV/TXT) for quick iteration and backup.
Minimal UX that would already solve it
In the {randomize} UI, add a “Bulk add / Import” button.
Accept CSV/TXT or Paste with line breaks.
Save as a named dataset that can be referenced by multiple snippets.
Why this matters
Massive time savings for users who rotate large lists.
Encourages reuse across snippets (single source of truth).
Makes {randomize} truly scale-friendly for long-term workflows.
Thanks for considering! This would make high-volume content work with Text Blaze far more efficient.
did you get a response to this? i need to import fro mcsv too
You can do pretty much all of this with formulas:
Let's say I have a CSV with three columns and I want to show the user a random color. Or maybe I want a random color weighted by the weights.
Here's how you can do both those things.
Row ID, Color, Weight
1, Green, 1
2, Red, 3
3, Blue, 2
I can do something like this in a snippet:
CSV:
{formparagraph: name=csv; default=Row ID, Color, Weight
1, Green, 1
2, Red, 3
3, Blue, 2}
Convert the CSV to a Text Blaze lists:
{list_rows=slice(map(split(csv, "\n"), row -> map(split(row, ","), c -> trim(c))), 2)}
Rows as list: {=list_rows}
{colors=map(list_rows, row -> row[2])}
{weights=map(list_rows, row -> row[3])}
Colors: {=colors}
Weights: {=weights}
Select a random color: {=colors[ceil(random() * count(colors))]}
{random_from_weighted_list=(items, weights) -> block
var sum = sum(weights)
var r = ceil(random() * sum)
var cumulative = 0
var index = 0
for w in weights
index = index + 1
cumulative = cumulative + w
if r <= cumulative
return items[index]
endif
endfor
endblock
Select a random color weighted by the weights: {=random_from_weighted_list(colors, weights)}
The logic is a bit complex. I think it may make sense to add a fromCSV and a sample function to Text Blaze to make this easier.
We now have two new functions in Text Blaze that make this task much simpler. Here's how to input a CSV and output a weighted random value from it:
CSV:
{formparagraph: name=csv; default=Row ID,Color,Weight
1,Green,1
2,Red,3
3,Blue,2}
{csv_values=fromcsv(csv)}
Select a random color: {=randomitem(map(csv_values, x -> x["Color"]), map(csv_values, x -> x["Weight"]))}
This snippet is much simpler than the previous snippet. The two new functions I used randomitem() and fromcsv().
I'm going to mark this request as solved :smiley: Feel free to let us know if you would like further clarification or examples for your use case.
