Hi
Would greatly appreciate any pointers in the following.
I have a list of formtoggle's that I have put into bullet points.
Example:
- {formtoggle: name=Option 1}{endformtoggle}
- {formtoggle: name=Option 2}{endformtoggle}
- {formtoggle: name=Option 3}{endformtoggle}
- {formtoggle: name=Option 4}{endformtoggle}
And then I want to add a formtoggle that appears if one of those formtoggle's has been toggled. And I need it to appear in conjunction to the toggled formtoggle.
Example:
- {formtoggle: name=Option 3}{endformtoggle}{if: Option 3=="yes"}{formtoggle: name=Option 3A; Option 3B}{endformtoggle}{endif}
What am I doing wrong above?
Hey @Robert_Shaw,
Thanks for the example.
Are you looking for something like this?
{formtoggle: name=Option 3}{endformtoggle}{if: `Option 3`=="yes"}{formtoggle: name=Option 3A}Option 3B{endformtoggle}{endif}
Yes, that worked perfectly. Thank you very much @VinodGubbala !
To add on that,
I don't know your exact use case. But in the above example you don't need the {if}
command. Rather you can just place contents of {if}
into {formtoggle}
{formtoggle: name=Option 3}{formtoggle: name=Option 3A}Option 3B{endformtoggle}{endformtoggle}
Yes, thank you very much @VinodGubbala . I have a bunch of formtext, formtoggles and other stuff that appear when it's being toggled, so I got everything I needed. I just didn't get them to appear by just toggling that one option. Thanks again!
