After updating google chrome, my snippets are no longer working in gmail. The extension turns gray when I click on my gmail tab.
Is there any way to fix this?
Hi @rkamel!
Do you have any other extensions installed? Other extensions may occassionally interfere with Text Blaze, especially on Gmail. If you do not, consider removing the Text Blaze extension and re-installing it, and see if the issue persists.
I hope this helps! If it doesn't, I can work with you in more depth on figuring out the solution.
