Kamuro
1
Hello,
I want to use links in formmenus, but it doesn't work:
{formmenu: name=TV producer:; {link: https://www.panasonic.com} Panasonic {endlink}; {link: https://sony.de/} Sony {endlink}; multiple=no}
I also tested:
{link: {=producer}} {formmenu: name=producer; https://www.panasonic.com; https://sony.de; multiple=no} {endlink}
What can I do to make it work?
Hi @Kamuro
The formmenu command doesn't accept commands, but you could combine it with an if command to achieve what you want:
{formmenu: name=options; option 1; option 2; option 3}
{if: options=="option 1"}insert link 1{elseif: options=="option 2"}insert link 2{elseif: options=="option 3"}insert link 3{endif}
Kamuro
3
Thank you Cedric_Debono_Blaze,
that's a very good idea! It works fine, but now i have the selection from the formmenu in addition to the result from the if-command in my Website:
Option 1
https://www.option1.com
Is it possible to hide the selection from the formmenu in the result?
@Kamuro, yes, you can hide the formmenu inside a note command:
{note}the formmenu command
{endnote: trim=right}
The if command
Kamuro
5
Perfect! Thank you very much.
You can also use it to import snippets based on your choice
Kamuro
7
Thats a nice idea. I will think about what else I can optimize with it. Text Blaze is a very excellent tool.
If you want you can tell me a bit more about what you want to achieve (and your use case) and I could help you develop some snippets.
