I wonder if there's a way that I could filter specific words in a clipboard? (I copied a paragraph that starts with 'Hi ,' and ends with 'Thank you'.)
Im trying to filter out
- Hi
- Hi ,
- Thank you,
- Thanks
Here's what I came up with while reading through the tutorials and community boards. Unfortunately its not working
Hi @Gerald_John_Amora1,
Use {clipboard} instead of simply clipboard. The following snippet would work. I used our newly released skill to generate it.
How it works:
- The inner replaceregex removes “Hi” or “Hi ,” (any spacing, with or without the comma) from the start of the clipboard.
- The outer replaceregex removes “Thank you,” or “Thanks” (with an optional ,, . or !) from the end.
- The "i" flag ignores case, so “hi”, “HI” and “thanks” are removed too.
- \b makes it match “Hi” only as a whole word, so a paragraph that starts with “Hilary…” stays as it is.
{=replaceregex(replaceregex({clipboard}, "^\s*hi\b\s*,?\s*", "", "i"), "\s*(thank you|thanks)\s*[,.!]?\s*$", "", "i")}
