I can create a snippet. And create a folder. How do I add snippets into the folder?
Hi @Sean_Armentrout ,
Welcome to the forum!
These are the two ways to create or add a snippet to a folder:
- You can right-click on the folder and create a snippet inside the folder
- You can drag and drop snippets from another folder to a folder
