How to add white space into my snippet to aid with formatting
My Chrome program strips any formatting out of my snippets. Then I thought of using reverse trim white space as a simple way to at least "tab" and indent a sentence. What is an easy way to trigger white space (which my program will sometimes allow) not remove it.
Thx in advance for any help.
In which website and field is this happening? Is it happening on other websites as well (like Gmail)?
If yes, can you please disable any other extensions you have and check it.
Thx for the response! I have branched yet to any other apps but it is happening in eCW (eClinical Works)
Can you please confirm by using the same in other websites like Gmail and let us know. Also test by disabling all other chrome extensions you have.
