Right now. If you try to make an equation based on two text inputs, the values in the text input is added before the equation results. There has to be a way to use the inputs for the equations and their values does not show up.
For example:
a form input has the number of apples and another the price then an equation to calculate the total cost. I need to be able to use the form inputs to enter the data and the command only gets the result.
There are a couple ways to do this. The two best ones are probably these two approaches:
Using the {note} Command
{note} defines a portion of your snippet that will not be used in the display. When inserted, the following snippet won't include the contents of the {note} block.
All the form inputs support a formatter function that takes the input and formats it for output. You can define a formatter function the returns a blank string to remove the form input in the output.
