seeking assistance because I ran into a roadblock and couldn't get this to work. I'm trying to create a toggle option that reveals a dropdown menu containing different regions. Once a region is selected, specific information should display based on that choice. I managed to make the dropdown feature work on its own, but I haven't been able to successfully integrate it with the toggle functionality.
PS : I need it to start with the toggle, as there are several other options that need to be present before the dropdown menu appears.
Thank you for your prompt response! I was finally able to make it work. I just want to ask if there's a way to filter out the dropdown choice so it doesn't appear in the actual outcome of the snippet?
For example, instead of getting 'USYou selected United States', I just want 'You selected United States' to show up.
Apologies, I don't think I explained the problem well. As you can see here, the drop-down for the snippet shows different regions as options for the prompt.
Hi @Gerald_John_Amora1 ,
Yes, that's what Scott meant with the note command. Whatever is inside a note will show up in the pop-up but will not be inserted as text. Here's an example:
{note}{formmenu: name=region; US; EU}
{endnote}{if: region="US"}
{elseif: region = "EU"}
Tou selected Europe
