I'm trying to create an email template with bullet points highlighting certain resources based on a customer's progress. The problem is, even if a conditional statement removes the resource, the bullet is still there:
I feel like there's probably a simple solution here but I haven't been able to make it work.
Hi, @Mira_Garrett,
Could you share the snippet (using dummy text) here please?
If you click on the gear icon in the reply window, it allows you to insert snippet syntax like this:
Snippet content: {formtext}
Hi @Mira_Garrett,
Thanks for sharing. I see now what you mean.
We're aware of the issue and are currently working on a fix for it. There should be an update in the near future.
Thanks for bringing it up
