The last letter of every snippet is incomplete... Did i change a setting?
Hi @Dustin_Falconer, welcome back to the forum. ![]()
Sorry for any inconvenience you're experiencing with Text Blaze. Could you please share a few more details about the issue, such as:
- Does it happen when inserting the snippet or inside the snippet editor in the dashboard?
- If it happens when inserting the snippet, does it occur in all apps or only specific ones?
- Which Text Blaze version are you using (Chrome/Edge extension or the Windows/Mac desktop app)?
- Can you share a screenshot or recording of the issue?
Please avoid sharing any sensitive information here; you can also email us directly at support@blaze.today with the details.
If my shortcut is: /ap for "apple" then when i type /ap it shows up "appl" I have to finish the last letter of every shortcut.
Hi @Dustin_Falconer welcome! Are you facing the issue both inside websites in your browser and inside apps on Windows, or just inside apps in Windows?
I work in a program on Windows; But now that you mention it, it appears to work ok on website search engine but in my program its not completing. I use xactimate for insurance and use it to label pictures.
Thanks for reporting this.
If the issue occurs consistently, could you please share a video recording of it happening?
