Inserting the 2nd recipient's first name not working for some
I am having an issue with a command used to split the gmail-firstname field.
Here is the current command:
{=split(split({gmail-firstname: type=multiple}, ", ")[1], " ")[3]}
This command works for me, but two other users are encountering errors. It appears the command is not recognizing the second email address in the "To" field.
When the affected users run the snippet, they receive the following error:
[Error - Position 3 is not in the list – it only has 1 items]
I replicated the issue a couple of times. In my testing, clicking back into the "To" field containing both email addresses resolved the issue and allowed the snippet to populate correctly. However, this workaround does not work for the other users. And now I cannot duplicate the issue because it works fine for me again.
Could you please look into this issue?
Hi Richard,
One thing first, you should switch type=multiple, to type=list. That will provide a native Text Blaze list, and you should be able to get rid of the splitting logic you have to break apart the specific items.
That may not fix the issue, though. Can you share a screenshot showing what the Gmail message (with the recipients) looks like for one of the affected users?
You can send it to support@blaze.today if there is anything sensitive in the screenshot.
