Hi
I've search the community but couln't find an answer...
Is it possible to add variable to BSQL command ?
I'd like to automatically add the data coming from a selector on a website to get a certain row of a table.
I've tried with the clipboard but I can't make it work, the variable is not replaced at query time :
{dbselect: SELECT Autocomplete FROM Conversations WHERE Email = {clipboard} LIMIT 1; space=xxxx; menu=no}
or
{dbselect: SELECT Autocomplete FROM Conversations WHERE Email = "{clipboard}" LIMIT 1; space=xxxx; menu=no}
or
I've double check, my clipboard contains an existing value.
