Is there a possibility to add over 100 folders?
Hey guys,
Is there a way to add more then 100 folders to my textblaze dashboard by any chance? upgrade or something?
Kind regards,
Hey Dominic!
If you need more than the default maximum number of folders in your dashboard, you could upgrade for more. Details on upgrade options and specific folder limits can be found on the Plans page.
Is the 100-folder limit something you're hitting because of the number of snippets, or because you need separate folders for different projects or clients?
I'm not sure whether upgrading changes that limit, but if you're managing a large snippet library, the folder structure could become a problem even after increasing the limit.
It would be useful to know whether Text Blaze supports a higher folder count on another plan, or whether this is a dashboard-wide restriction.
If it's a fixed limit, nested folders or better tagging might be more useful long-term than simply raising the number.
