Need help with the lookup formula (subtraction)
I want to substract # Current Stock with Stock Update (lookup)
How can I do this?
Thank you in advance
Hi @bukit,
Lookups are lists of values, because you can have multiple rows linked. So probably what you want to do here is to have a list where each element is `Current Stock` - `Stock Update`.
The final formula could look like this:
[`Current Stock` - x for x in `Stock Update`]
This is list comprehension which create a list from Stock Update and for each element of Stock Update (which is defined as x) it will create expression `Current Stock` - x.
The resulting value is going to be list. If you always have only one value you could update the formula:
[`Current Stock` - x for x in `Stock Update`][1]
The resulting value in this case is going to be single value not list.
Let me try.. thanks :pray:
It works :smiley:, made my day.. thanks again :handshake:
