Hi there!
I've got a snippet that is a contract of sorts with numbered paragraphs. I've inserted a table after paragraph 7. I cannot for the life of me figure out how to get the next paragraph, after the table, to be number 8 instead of 1. In word or good docs I am able to format the numbering to start at 8 on the new section, but no such luck in Text Blaze. Any help would be great. Example below:
Table
(Should be 4.)
2
Hi @Samantha_Galltin,
Welcome to Text Blaze community.
Currently, the table feature is still in beta testing and has some issues with supporting different types of editors. We are unable to support various formats when a table is included, including lists.
Therefore, at the moment, it is not possible to start the numbering at 8 after a table. However, we appreciate your feedback and will take it into consideration for future updates. Thank you for your input.
Thank you Vinod. I appreciate the quick response!
