I've been trying to solve a problem for a while now that would be helpful if Text Blaze could do it. It would essentially require the ability to do some light manipulation on text and read from either a CSV or a pasted value. Here is what I need to do:
For a person with a name like John Smith that works at Bank of America with an email like john.smith1@bankofamerica.com and a password like V%42144*Tl288
make an account and automate the entry into a system based on tabs
jsmithboa{key:tab}<this is what I really need to make "j" & "smith" & "boa" john.smith1@bankofamerica.com{key:tab}
John{key:tab}
Smith{key:tab}
V%42144Tl288{key:tab}
{import:#account_num}{key:tab}
{import:@current_date}{key:tab}
{key:enter}
You can use Text Blaze functions to split apart CSV files into their different fields and also to extract parts of a string to create other strings. Here are a list of available functions:
It sounds like you can do everything you need here with Text Blaze, but you'll need to be a bit more precise what your input data is and what the output formats are you want, if you would like more detailed advice.
Assuming you have a tab delaminated CSV row copied to your clipboard (which will likely be the default when you copy from any spreadsheet app), you could do something like the following
