Remove spaces when using toggle field
Hi there. I need your help. I have a snippet which triggers 4 toggle fields. I can choose which to use from those. The problem is that whenever I select one and insert it, it adds some space, related to the order they have within the snippet. For example, let´s say I have 4 toggle fields like this:
Response 1
Response 2
Response3
Response4
Only if I select the first toggle field it does not add a space, and the space increases when I select the response 4. I do not know if this has been solved previously. I appreciate your response.
I figured it out, using the TRIM feature. Thanks.
