I have fixed data about 5-10 companies e.g. Company, Address, Code.
I have created one snippet wherein I want if I select name of Company 1 from dropdown, its corresponding values for address and code should automatically be filled up in snippets.
I understand this might be possible but not able figure out, first how and where to store such values. Can someone please help? @Cedric_Debono_Blaze @scott
Hi @Pratik_Shah,
Great question!
You could do this with keyed lists, which you can read more about here: Text Blaze | Formula Reference
Here's an example of how you could do that:
{note: preview=no}
{CompanyA=["Name"="Name of company A", "Address"="the address of company A", "Code"="The code of company A"]}
{CompanyB=["Name"="Name of company B", "Address"="the address of company B", "Code"="The code of company B"]}
{endnote: trim=right}
This is what the lists look like:
{=companya}
{=companya}
Here's how to use them:
{=CompanyA.Name}
{=CompanyA.Address}
{=CompanyA.Code}
{=CompanyB.Name}
{=CompanyB.Address}
{=CompanyB.Code}
This is obviously a very barebones example, but I can help you craft something better suited to your use case if you give me more details
This looks so great. I am definitely looking forward to use this efficiently for my use case.
I will definitely need your help in setting this up. I am working on bigger project exclusively using TextBlaze for which I would need your help.
I will get back to you once I set up basic structure of it.
Thank you so much
Absolutely. It's not only my job, I REALLY enjoy working out these challenges, so hit me up anytime!
@Brad_Hedinger @Santa_Laren and many others will confirm how obsessed I am
