I am not sure if I understood your use case correctly but here is a snippet which I created after some changes in the original one.
{run: medicines =[]
Medicines List:
{repeat: for medicine in medicines}
{=medicine} every {formmenu: default=8; 16; 24} hours{button: var index = location(medicines, medicine)
medicines = merge(slice(medicines, 1, index - 1), slice(medicines, index + 1))
; label=❌}{endrepeat}
New Medicine:
{formtext: name=medicine; default=} {button: if medicine = ""
notify("Medicine cannot be blank")
return
endif
medicines = merge(medicines, [medicine])
medicine = ""
; label=Add Medicine}
Hi, Ashwin.
Yes that my idea but I was thinking about the posibility of make different selections or formmenu for each "Medicine".
Really, thank you so much,
Luis
Do you mean that the frequency options would change depending on the medicine?
Ex.
Propranolol would show options: every 8 hours, every 12 hours
Acetaminophen would show options: every 6 hours, every 8 hours
Yes, @Timothy_Wong, that's the issue.
Something like this?
{formmenu: Med1; default=Med2; Med3; name=Medication}
{if: contains(medication, "Med1")}{formmenu: every 2 hours; default=every 4 hours; every 6 hours; name=Freq1}{endif}
{if: contains(medication, "Med2")}{formmenu: every 4 hours; default=every 6 hours; every 8 hours; name=Freq2}{endif}
{if: contains(medication, "Med3")}{formmenu: every 6 hours; default=every 8 hours; every 10 hours; name=Freq2}{endif}
Hi @Luis_Andres_Herrera,
In my previous solution, you can easily make different selections for each medicine you add or do you want to add a specific form menu for each medicine, for example, medicine 1 can have options for every 4 or 8 hours, while medicine 2 can have options for 2, 4, or 6 hours?
