If I understand your question, you want two {formdate}'s one set to seven days after the other.
If so, that's not really possible as you have to be able to set the values of each of the {formate}'s, but your 7 day constraint links them together making that impossible.
Instead, I would suggest using one {formdate} and then using the {time} command to display the shifted date in the second spot.
Here is an example:
The book is due: {formdate: LL; name=due}
We'll charge you for it 7 days later: {time: LL; at={=due}; shift=7D}
