I want to create a formtext field where I specify a number, and then shift time or date by that parameter.
Here's how I've tried to do it (and failed):
{ formtext: name=offset; default=1 }
{ time:MM; shift=+&offset&M }
You would do something like:
Shift: {formtext: name=offset; default=1}
Shifted month: {time:MM; shift=+{=offset}M}
The "&" operator to concatenate strings is only valid within an equation ({=}).
Thanks for the help! Sorted
