I have a shortcut trigger "/ov" but I am finding just typing "ov" fills in the text. For example when I want to type the word which has the opposite meaning to 'under' (literally cant do that word because I get this text fill ...." cv4 + OP
⨌ cv4 + ?3x DC?
or!!!
⨌ cv4 + ?DC? + 2?pts (as per chart)"
Can someone help with this, please?
Actually, I have worked it out...I also had it as a snippett!
Hi @Peter_O_Dwyer - welcome to the forum.
This is probably caused by the trigger settings in your snippet folder.
Try the following please:
- In your Text Blaze Dashboard, click on the folder that contains your snippet
- Under "Snippets trigger" (right sidebar, below "Folder options"), click on the dropdown menu
- Choose "Started by Word Break"
You can see the steps in the screenshot below.
You'll probably find that your folder was set to "Anywhere".
You can read a more detailed explanation of how triggers work here:
Let me know if that helps.
