Snippets for Marketplace
Do snippets I want to submit to the Marketplace need to be in a dedicated folder
Hi Tony,
We are in contact via email, but yes, snippets need to be in a folder, and then you just share that folder in the Marketplace.
Thank you for submitting your templates; we really appreciate it!
So, does each snippet submitted need to be in its own unique folder
No, not necessarily. You can have multiple snippets in one folder and share that folder.
Sorry to go on. when I share the folder, would I get to choose which snippet I wish to submit
No worries! No, when you share that folder in the marketplace, you are sharing all of the snippets in that folder.
If I make a change to an underlying snippet, will that be reflected in one under review or do I have to resubmit it as a new share
Hi Tony,
You can click on the "Edit and Submit" button on the bottom right, and that will reflect the changes. You don't have to submit again.
