I've changed a few shortcuts and snippets, and when I type them they either haven't changed or don't work at all! How can I fix this???
Hi, and welcome to the forum!
Please check this FAQ entry which has instructions for this type of issue:
Specifically, please try to reload the extension as it describes.
Also, make sure you don't have duplicate shortcuts. I've been guilty of that many times
One point which I can't see mentioned in the help files is that you have to make sure that cookies for Text Blaze are enabled, especially if Chrome is configured to delete those which aren't specifically set to be kept when you close the browser.
I had this issue at one point, but adding https://dashboard.blaze.today to the list of cookies solved the problem.
