Hello everyone,
A couple of hours ago, we did a soft launch for a brand new Text Blaze feature — Command Packs.
Command Packs will open up a whole new world of functionality in Text Blaze, making your snippets more powerful but easier to create.
If you open your dashboard and click on any snippet, you'll see a new icon in the bottom menu.
This is where you come in. We'd like you try exploring the feature and tell us about your experience with it.
Please feel free to speak openly. The only way this feature will serve its purpose is if it fits your needs and makes your lives easier
We look forward to hearing your thoughts!
Important: Command Packs are still in Beta, which means that they are still in development and may change in the future. You may also encounter some rough edges.
P.S. Command Packs are disabled by default for members of Text Blaze Business organizations. The organization admin can enabled them on the "Advanced Options" page for the organization.
