I have some snippets for whole emails, parts of which are in bold, and I have formtext tags in both bold and non-bold areas. If I make a text section that has a formtext tag bold, it doesn't stick. When I use the snippet the formtext content is not bolded. How can I preserve this kind of formatting?
I have also faced similar issue. It may be happening because of the formatting of your destination. Make sure your formating is clean in your email box.
Thanks for the reply. It's not the email box, as it's hit or miss whether the formtext fields are bold even in the previous window when you're filling out all the information. ¯_(ツ)_/¯
Hi, and welcome to the forum Brandon!
If you make the entire formtext bold, the output should be bolded to.
For example:
Hi {formtext},
Should output:
Hi Name,
Is that not what you are seeing? If so, could you create a simplified example simple that exhibits the issue and share it here?
