Hello! I have a snippet that will assign work to a specific user every time, using the Automation features. The opportunity I am faced with is, how to handle a temporary change to that user assignment when the user is out on vacation. Is there a way (and preferably with the "Basic" plan features), to do this?
Thank you!
-Brad
Hi @Brad_Hedinger ,
I'm thinking you could use an {if} command to do that. Something like:
[snippet]
{note}Format DD/MM/YY
{startdate="01/03/21"}Start date: {=startdate}
{enddate="01/05/21"}End date: {=enddate}
{endnote: trim=right}
Today's date is {time: MMMM Do, YYYY}
{if: {time: X} >= {time: X; at={=startdate}; pattern=DD/MM/YY} AND {time: X} <= {time: X; at={=enddate}; pattern=DD/MM/YY}}Date is within range{else}Date is outside range{endif}
[endsnippet]
What do you think?
