Text Blaze stopped working right after I upgraded to the Pro plan
Text Blaze stopped working right after I upgraded to the Pro plan. Does anyone know what could have happened? None of my snippets are working anymore.
Hi @Huynalmar_Segundo Welcome to the forum! :slight_smile:
Have you tried to restart the computer or restart the desktop app, and did that work for you? To restart the desktop app, you can quit it from the System Tray in the bottom-right corner of your taskbar.
I'm happy to also have a call with you to check this issue live, if that helps. You can email me on gaurang@blaze.today
Hello, yes! It works again!
Thanks
