Text Blaze works in Microsoft Edge?
I am having issues when I try to use my shortcuts in Edge, mainly on the Office websites, like Excel or Word.
Every time I have to reload the extension or have the dashboard open and click on it so that I can use the snippets, is Text Blaze compatible with Microsoft Edge?
Hi @n21406 Welcome to the forum! :slight_smile:
Text Blaze extension should work fine on Microsoft Edge. Can you please share exactly what is the issue when you use Text Blaze snippets on the Word online website?
I use my snippets for my work; I created many shortcuts to leave notes faster without copying and pasting. Specifically on the Excel website, the snippets won't work unless I reload the extension or click on the dashboard, which I always have open.
I have to do this every time I want to use a snippet; I don't get any error, it's just when I try to use a shortcut, it doesn't work on Excel.
Thanks for the info. Does it make a snippet trigger sound or show any confetti when you try the shortcut in Excel?
Can you share a screenshot of where in Excel you are trying your shortcuts?
After reloading the extension or clicking on the dashboard, it works.
↓↓ For example, this is one of my snippets: /pic
This happens only in Excel. After using the form, I have to reload the Text Blaze extension every time, and when I try again, it works, but seconds later, it won't work again. ↓↓
I've reloaded the extension and the snippet worked, but only after refreshing Text Blaze. ↓↓
Thanks for the details. That's quite unexpected. I just tried Text Blaze in Excel Online, and it works fine on my end. It looks like Text Blaze doesn't even detect the shortcut in your case. I will email you so we can set up a quick Google Meet to troubleshoot this further.
